I have the ArcGIS for server image extension (server and desktop 10.3), and am trying to publish a cached map service using a mosaic dataset. The mosaic dataset references .sid rasters. When I try to publish the service, I get the error "packaging succeeded, but publishing failed". My server logs show two related messages:
- WARNING: The Layer:'Image' in Map:'Layers' is invalid Source: System/Publishing Tools.GPServer
- SEVERE: Instance of the service 'System/PublishingTools.GPServer' crashed Source: Same as above
No error report is generated on the server.
Any ideas before I call Esri Support?
