Hi @PeterBecker . Look at these two images. Sentinel-2 Views as before, just a different area. Identical everything, I just moved the frame up slightly in the Layout between image 1 and 2 to demonstrate that the blocky look is clearly coming from a processing workflow in the pdf export as opposed to stitching Sentinel Tiles together. If it were Sentinel tile edges the block borders would be in the same place, but they occur halfway down the layout consistently.
I've tinkered with the export options that seemed impactful, including Compression = jpg, adaptive, None, but SAME issue:
End of the day, my only solution was to export as PNG (instead of the desired PDF). This worked - but, if you have any thoughts on why PDF is not working, that would be appreciated.
Thanks - Zach
