Can't Access Insights "you don't have permission to access Insights for Arc GIS"
4658
19
10-29-2017 06:13 AM
ahmed_hussiney
New Contributor III
Hi I have installed #insights, then imported a valid entitlement, and I am logged in as a level 2 user, but when I try to open Insights it show invalid redirect URL and after some researchers in GeoNet I found a solution for invalid redirect URL issue by settings app redirect URLs for both http and https , but then It keep show me "you don't have permission to access Insights for Arc GIS" although I am logged in with user who is admin and level 2 with permission for insights license, any recommendataion how to fix this ??
You don
My user permission
ahmed_hussiney
New Contributor III
Hi All,
I had fixed this issue by specifying both the http and https redirect URLs of insights app check the following post for more details
Invalid redirect_uri Error: 400
Another thing I need to highlight that some problems that we faced was show only on Internet Explorer so I recommend when you test your environment use either chrome or Firefox.
Please let me know if this fix work with you too.
XanderBakker
Esri Esteemed Contributor
In Portal, did you assign a Insights licence to your user?
ahmed_hussiney
New Contributor III
 Yes I did that
CraigCleveland
Did you find resolution to this issue?  I'm seeing the same thing, and cannot find a fix...
WilliamDeGraw
New Contributor III
JD was getting this message today. He had the license but was set as a USER role. After I elevated him to Publisher role...screen block was removed.
CraigCleveland
Thanks for the response Ernie.  To utilize Insights you must be an L2 user, have an Insights licensed assigned to you, and be in the publisher role.  In my case all of those things are in place, but the problem still persists...
AravindStoryMaps
Hi Ahmed & Craig,
Sorry for the late reply to this. Are any of you still having issues with this in Insights for ArcGIS for any named users of Portal?
Aravind
CraigCleveland
Yes, I've still got issues with this.  No resolution to date...
ammaralotoom1
Hi All ,
Did any one solve it? I have the same issue ..
Thanks ,
Ammar
CraigCleveland
Hey Ammar,
Unfortunately I have not been able to solve this to date.
Craig
