Popup Configuration?
1376
04-12-2017 06:52 AM
AndrewHargreaves
Occasional Contributor II
Hello
Is there a simple way to configure the popups in Insights map to show any attribute I want?
AravindStoryMaps
Hey Andrew,
Insights doesn't support adding custom fields from the layer in the hover-over popup feature. Hover popup content depends on the type of renderer (Layer Style) and doesn't list all the fields like ArcGIS Online/Portal for ArcGIS.
Aravind
AravindStoryMaps
Hey Andrew,
Aravind
ChrisWalker5
How does Insights determine which field to display as a popup on the map? I am wanting to view block groups and show their ID as a popup. However, Insights keeps showing a text field that is the 6th text field in my dataset. It doesn't seem like there is any particular reason why its choosing this field that I can tell.
