I have used an ESRI template which was downloaded from GitHub and I want (a) to change the dimensions or position of the frame which includes the title and (d) to add more widgets.
Solved! Go to Solution.
Thanks a lot!!!!!!!
I am glad I could help
Hello Rickey
I tried to send you an inbox message but it says that I can only send you one only if we are friends.... So I will ask you from here...
Do you know any course that I can participate (free or payable) for webgis (I need more knowledge about the "designing part" like the correct symbology, etc.) and particularly for web appbuilder (I know the basics but I need more knowledge mostly for css and html parts)??
I leave in Greece so anything e-learning is acceptable.
Barbara,
Have you looked at ESRI online training, they have this course:
Creating Web Applications Using Templates and Web AppBuilder for ArcGIS
Barbara,
Sorry I must have missed your response. What Saloni recommended would be good also there is this resource:
Web AppBuilder Developer Edition - Customization Resource List
