Improve media pagination experience in Popup
2064
07-23-2023 11:18 PM
Status: Implemented
StefanUseldinger
Occasional Contributor II
With ArcGIS Maps SDK for JavaScript version 4.27 an improved media pagination experience was introduced.
In case of multiple media elements, this works well. However, if there is just one element to show, I think it isn't necessary to show the "1 of 1" label as pagination isn't possible here.
This behavior is not coherent as the feature pagination won't show the "1 of 1" in the corner in case of a single feature hit.
The option to disable the "1 of 1" label should be handled automatically or manually controlled by the VisibleElements property.
Tags (3)
5 Comments
LaurenBoyd
Thank you for the feedback and idea! This is something we are considering for a future release.
LaurenBoyd
LaurenBoyd
This has been implemented for version 4.28 and can be tested by using the next CDN. Here's an example application showing the new behavior: https://codepen.io/laurenb14/pen/MWzZrJJ?editors=1000
BjornSvensson
BjornSvensson
