4.7 - Untitled Layer is being visible in layerList Widget when i define new SketchViewModel
1771
05-16-2018 12:55 AM
TubaKumbara
hello.
I defining a new graphicslayer which has listmode property value as "hide". And this graphicslayer doesn't show in layerlistwidget (this is what i want)
var myg = new graphicsLayer({
    listMode: "hide";
mymap.add(myg);
new sketchView
var s = new SketchViewModel({
   view: mySceneView,
   layer: myg,
when i run this code an Untitled Layer is being visible on layerlist.
This layer is not myg. Another new layer.
RobertScheitlin__GISP
Tuba,
   I see what you are talking about and the only way to fix this I have found is with this work around (lines 18 - 24):
      view.when(function() {
        var layerList = new LayerList({
          view: view
        // Add widget to the top right corner of the view
        view.ui.add(layerList, "bottom-right");
        // create a new sketch view model
        var sketchViewModel = new SketchViewModel({
          view: view,
          layer: tempGraphicsLayer,
          pointSymbol: pointSymbol,
          polylineSymbol: polylineSymbol,
          polygonSymbol: polygonSymbol
        setTimeout(function(){
          layerList.operationalItems.items.map(function(item){
            if(!item.layer.title && item.layer.type === "graphics"){
              item.layer.listMode = "hide";
        }, 200);
You really need to log a bug with esri tech support on this.
UndralBatsukh
Hi there,
We will address this issue in our future release. Thank you pointing it out.
ChesouyeCoye
I am having the same issue. I have attached a snippet. I do not know why there is a untitled layer as I have done weeks of debugging and it doesnt work. untitled layer.PNG
JustinCarasick
I figured a workaround with this. I had to hit a private member and use it's hide setting.
this.sketchViewModel._defaultGraphicsLayer.listMode = "hide";
