Add own basemap to Basemap Gallery, but doesn't behave as part of the Gallery.
4127
07-08-2014 11:42 AM
DorothyMortenson
Occasional Contributor II
I have added the USA Topo maps to the BasemapGallery.  Works great in the widget as an option to choose from.
But I want to make the USA Topo maps the default for the web application.  I cannot seem to get it to recognize the new layer.
For now, I have set the basemap to be "gray".
Then I make the BasemapGallery.
Then, when the user zooms in, it should change to my new basemap.  This code works if I change the basemap to "topo" or one of the other ArcGIS basemaps. But it won't get the usatopo basemap.
In this example, I also add the google maps. I'd be interested in knowing how to select one of the google themes as a basemap.
But first things first, - how do I get the usatopo to be the default?  If I make it a tiled layer and add it as a map layer ( as in using map.addLayers([usatopo]) , then it covers the other basemaps, if someone switches to one of those. So it's acting like a layer and not a basemap.
Thank you.
map = new Map("map", {
            center: [-120.6, 44],
            zoom: 7,
            basemap: "gray",
            sliderOrientation: "vertical",
            sliderStyle: "small",
            fadeOnZoom: true,
            force3DTransforms: true,
            showAttribution: false,
            navigationMode: "css-transforms"
map.on("load", function () {
            otherMapFeatures();
            this.map.on("zoom-end", task);
function task() {
            this.map.setBasemap("usatopo");  // this work with "topo"
function otherMapFeatures(){
var mybasemap = [];
var usatopo = new BasemapLayer({
                url: "http://services.arcgisonline.com/arcgis/rest/services/USA_Topo_Maps/MapServer"
            var myUSATopo = new Basemap({
                layers: [usatopo],
                title: "USA Topo",
                thumbnailUrl: "images/usatopo.png"
            mybasemap.push(myUSATopo);
            var basemapGallery = new BasemapGallery({
                showArcGISBasemaps: true,
                basemaps: mybasemap,
                map: map,
                google: {
                    apiOptions: {
                        v: '3.6' // use a specific version is recommended for production system.
                    mapOptions: {
                        streetViewControl: false
            }, "basemapGallery");
            basemapGallery.startup();
         basemapGallery.on("error", function (msg) {
                console.log("basemap gallery error:  ", msg);
JohnGravois
i'd recommend listening for the startup event of the BasemapGallery and then calling BasemapGallery.select() with the id your USA topo layer.
https://developers.arcgis.com/javascript/jsapi/basemapgallery-amd.html#select
JohnGravois
DorothyMortenson
OK, finally got it to work.
basemapGallery.select("usatopo") - what I used for the ID when I defined it.
Just a note here: This is not the same for "topo".  "topo" is not the ID of the standard topo theme.  The ID is more like "basemap_5" and I think the numbers change.  I used the following to find out what the actual ID and title are called.
first make the selection in the gallery, then call a function that includes:
var a = basemapGallery.getSelected();
console.log("a " + a.id + " " + a.title);
