Hi all. I am trying to add a button to the dgrid so that the user sees a magnifying glass instead of the objectid, since I don't want the end-user to see the objectid. I tried adding the following code:
window.grid = new (declare([Grid, Selection]))({
// use Infinity so that all data is available in the grid
bufferRows: Infinity,
columns: {
"id": {"label": "ID", "formatter": makeZoomButton},
"vehicleId": "Vehicle ID",
"velocity": { "label": "Speed (MPH)", "formatter": dojoNum.format },
"timestamp": {"label": "Last Contact", "formatter": formatTimestamp}
}, "grid");
function makeZoomButton(e){
zBtn = "<div data-dojo-type = 'dijit/form/Button'><img src='images/zoom.png'";
zBtn = zBtn + "width='14' height='14'";
zBtn = zBtn + "onClick=\"selectUnit('"+e+"')\"></div>";
return zBtn
I already had this existing code for zooming to the feature:
grid.on(".field-id:click", selectUnit);
function selectUnit(e) {
// select the feature
var flzoom = map.getLayer("units");
var query = new Query();
query.objectIds = [parseInt(e.target.innerHTML)];
flzoom.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(result) {
if ( result.length ) {
point = result
// re-center the map to the selected feature
window.map.centerAndZoom(result[0].geometry, 100);
} else {
console.log("Feature Layer query returned no features... ", result);
The existing code works when the id field doesn't have a formatter, but when I insert the formatter, the grid still shows up, but when I try to click on the magnifying glass, it gives this error: SCRIPT5009: 'selectUnit' is undefinedAny help is greatly appreciated, thanks!Michelle
