I've got problem, I'm creating map based application, and now I have to add to map about 100 000 graphic points, from coordinates. I was trying in many ways to do it, but always process of adding points takes about 7-10 secounds, or my web browser just hang on.
is it even possible to add this amount of data to map without having problems with performance?
thanks for any advices!:)
var layerSelectedBoreholes = new esri.layers.GraphicsLayer({displayOnPan: false}); var length = points.length; var tmparray = []; var i = 0; while (i < length){ tmparray.push(points); i++; if (i % 1000 == 0){ pointsPart = getMultiPointFeature(tmparray); var gra = new esri.Graphic(pointsPart); layerSelectedBoreholes.add(gra); console.log(i); tmparray = []; } } function getMultiPointFeature(points){ var multiPoint = {"geometry":{"points":points,"spatialReference":2180}, "symbol":{ "style":"STYLE_CIRCLE", "size":3, "color":[0,0,0,255], "type":"esriSMS", "outline":{ "style":"STYLE_SOLID", "color":[0,0,0,255], "width":0, "type":"esriSLS" } } }; return multiPoint; }
it works just fine, up until 4600 points - any more, and the map simply doesn't draw. Any ideas as to why that might be?
now I'm testing many options to add points. I get points coordinates from an array, then to avoid hang up a web browser I'm spliting data for parts (1 part = 1000 points) and then tryin to add via API function. My code looks like:
points is an array with coordinates in format [[x1,y1],[x2,y2].....[x100000,y100000]];
