I'm creating graphics layer with ajax return. I can see the graphics layer in the map, but the points don't appear on the layer, I'm adding the points but somehow something seems missing. Jen is an object that's holding most of the map elements. EDIT: I'm now getting a new error here's the reformated code: **Error: Problem parsing d="Z"**
$.ajax({
url: opt.url,
type: 'GET',
dataType: 'json',
error: function(error) {
console.error('error: ' + error);
jen.ajaxData.points = {
"points": [
[-122.63, 45.51],
[-122.56, 45.51],
[-122.56, 45.55],
[-122.62, 45.00],
[-122.59, 45.53]
"spatialReference": ({
"wkid": 4326
success: function(data) {
console.info('ajax is successfull');
jen.graphicObj = {};
jen.graphicObj.Layer = new esri.layers.GraphicsLayer();
for (var i = 0; i < (data.length); i++) {
jen.ajaxData.long.push(data.latitude);
jen.ajaxData.lat.push(data.longitude);
jen.ajaxData.num.push(data.number);
jen.ajaxData.idleTime.push(data.idelTimeMinutes);
"points": [jen.ajaxData.long, jen.ajaxData.lat],
"wkid": 4326
jen.graphicObj.geometry = new esri.geometry.Multipoint(jen.ajaxData.points);
jen.graphicObj.infoTemplate = new esri.InfoTemplate(//);
jen.graphicObj.graphic = new esri.Graphic(jen.graphicObj.webMercator, jen.circle, '', jen.graphicObj.infoTemplate);
jen.graphicObj.webMercator = esri.geometry.geographicToWebMercator(jen.graphicObj.geometry);
jen.graphicObj.Layer.add(jen.graphicObj.graphic);
} //end of success function
}).done(function(){
//layers get added in a loop after this point
