Any way to hide an infoWindow on a mouse click?
3249
16
05-13-2012 08:21 AM
JayGregory
New Contributor III
Was curious if anyone's found a way to hide an infoWindow when a user clicks outside the infoWindow (instead of having to click the "x" or click on another map graphic which displays another infoWindow.
I tried setting a dojo.connect event handlers like dojo.connect(map, "onClick", map.infoWindow.hide()); but that doesn't seem to work.
Thanks!
Jay
StephenLead
Regular Contributor III
But clicking on a graphic would then also constitute a click on the map
You can trap for that using:
dojo.connect(map, "onClick", function(evt) {   if(!evt.graphic) {     console.log("map click");   } });
StephenLead
Try this instead:
dojo.connect(map, "onClick", function() {
  map.infoWindow.hide();
JayGregory
New Contributor III
Thanks for the suggestion.  That just seems to hide the infoWindow as soon as it's shown - it's only up for a second.  I also tried
dojo.connect(map.infoWindow, "onShow", function() {
and that didn't seem to work either.  Same behavior - just hides the infoWindow right away.
Jay
StephenLead
It sounds like you might be using a mouse click on the map to open the infoWindow in the first place?
What's displayed in the infoWindow - can you trigger it to open when you click on something else( a feature, graphic, or layer) instead?
Steve
JayGregory
New Contributor III
The infoWindow only shows when you click on a graphic.  But clicking on a graphic would then also constitute a click on the map, which fires the infoWindow.hide() function too, hence the hiding.  I tried setting a handler to only connect the infoWindo.hide() on a mouse click _once_ the infoWindow is shown.  And then as soon as the infoWindow is hidden, diconnect the event handler.  But that didn't work either.
StephenLead
DavidTreering
New Contributor II
Is there a way to do this yet?  I have the InfoWindow closing automatically by a number of different events,  using:
   function hideInfoWindow(){
But I can't find an "event" for clicking on the map anywhere to close the infoWindow.
JayGregory
New Contributor III
Thanks Steven!  That did it!
DavidTreering
New Contributor II
I'm pretty new to JS and I didn't quite get this yet.  Can you explain what I need to do to this?
     if(!evt.graphic) {
     hideInfoWindow();
JayGregory
New Contributor III
In your case, the hideInfoWindow() is executing outside the if statement - that is, no matter if you clicked on a graphic or not.  You need to move the hide statement inside the if statement, although you can make it simpler by just attaching this handler instead - no need to call the extra function just to execute one line of code.   The !evt.graphic means "if you didn't click on a graphic".  Hope that helps!
  if(!evt.graphic) {
