I am using arcgis 10.1 and JS 3.2. I have a featurelayer with field name "DATE" and the layer shows data on web map when I use definitionexpression using "DATE" field. When I use print task, however, it does not catch any data from the server. After I spent a lot of time to solve this, I figured out that it works okay when I change the field name from "DATE" to "DATE_". I know that "DATE" is a reserved word in several DBs but it's not in arcgis geodatabase. Can someone look at this? We need to keep field name as "DATE".
Thanks.
