Arcgis Javascript Routing API.
116
04-16-2024 06:53 AM
CastielMye
Hi! I'm currently doing routing applications and using the routing API. When I pass the list of stops, the API returns less than the count of stops. The stop count is 150, and I expect an output of Path count 149. but then it's way less than the expected count. The thing that I saw is that there is a similarity between snapX and snapY. Are there ways to not exclude other stops and just output the paths needed, even if the path long lat or stop long lat are duplicated?
