Try this URL: http://js.arcgis.com/3.7/
<script type="text/javascript"> dojo.require("dojo.parser"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.TabContainer"); dojo.require("dijit.layout.AccordionContainer"); dojo.require("dijit.form.Button"); dojo.require("dijit.form.CheckBox"); dojo.require("esri.map"); function . . . . </script>
Hard to tell what is going on but judging from the screen grab you may need to remove the top curly brace '}'. If you are using the non-AMD style for calling dojo modules they should be placed at the top of your script tag. Here is an example from an old version of mine.<script type="text/javascript"> dojo.require("dojo.parser"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.TabContainer"); dojo.require("dijit.layout.AccordionContainer"); dojo.require("dijit.form.Button"); dojo.require("dijit.form.CheckBox"); dojo.require("esri.map"); function . . . . </script>
Hopefully this helps.
On another note, if your are just starting out developing your web app I strongly suggest that you adopt the AMD style of using dojo. The non-AMD style will be obsolete in the future, so better to adopt the new style now rather than later.
Sorry I couldn't be of more help. The service is definitely up and running though; I'm working on my app right now without any problems.
