I am wondering how to get the geolocation icon in the ArcGIS JS API 4 locate widget to look and behave more like the My Location Widget from the WebAppBuilder on a mobile device. I am aware that WAB uses JS API v3 but I would think it must be possible to get similar look and behavior in v4. The WAB widget on a mobile device has an accuracy buffer and the flashlight that shows the direction you are facing. I also tend to believe in my own comparison using the same device at the same location, the GPS accuracy of the My Location Widget in the WAB was better than the location widget in ArcGIS JS 4 API. Do they both not use HTML5 Geolocation? You can see in the screenshots below the visual differences between the two widgets.
