ArcGIS map service layer not loading properly at full extent
546
02-25-2014 04:25 AM
BenjaminBauman
My initial problem was an issue with the layer not loading at all when the page was set to the full extent, despite having changed the Min/Max Scale settings generously when publishing the map service. I corrected this by rectifying the Scale settings in JavaScript:
landBaseLayer.on("load", function() { landBaseLayer.minScale = 0; landBaseLayer.maxScale = 0; });
I now have a problem with the layer not loading when entering the page. It loads when I zoom in, and the loaded subset will remain visible when I zoom back out, but everything around it will remain blank. What am I doing wrong? Sorry, I'm totally new to this. I'm using a cached map service, with a Max Record Count of 10,000 (the layer contains just over 7,000 points). The following is the entire code.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
  on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Identify with Popup</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
<style>
  html, body, #map {
    height:100%;
    width:100%;
    margin:0;
    padding:0;
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="http://js.arcgis.com/3.8/"></script>
<script>
  dojo.require("esri.map");
  dojo.require("esri.dijit.Popup");
  var map;
  var identifyTask, identifyParams;
function init() {
    //setup the popup window
    var popup = new esri.dijit.Popup({
      fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25]))
    }, dojo.create("div"));
    map = new esri.Map("map", {
      basemap: "satellite",
      center: [-89.211, 39.977],
      zoom: 7,
      infoWindow: popup
    dojo.connect(map, "onLoad", mapReady);
    var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/WeekSample/MapServer",{opacity:.55});
    map.addLayer(landBaseLayer);
  function mapReady(map){
   dojo.connect(map,"onClick",executeIdentifyTask);
   //create identify tasks and setup parameters
   identifyTask = new esri.tasks.IdentifyTask("http://localhost:6080/arcgis/rest/services/WeekSample/MapServer");
   identifyParams = new esri.tasks.IdentifyParameters();
   identifyParams.tolerance = 3;
   identifyParams.returnGeometry = true;
   identifyParams.layerIds = [0];
   identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
   identifyParams.width  = map.width;
   identifyParams.height = map.height;
  function executeIdentifyTask(evt) {
    identifyParams.geometry = evt.mapPoint;
    identifyParams.mapExtent = map.extent;
    var deferred = identifyTask.execute(identifyParams);
    deferred.addCallback(function(response) {
      return dojo.map(response, function(result) {
        var feature = result.feature;
        feature.attributes.layerName = result.layerName;
        if(result.layerName === 'Bloomingdale_Parcel'){
          //console.log(feature.attributes.PARCELID);
          console.log(feature.attributes.UNIQUEID);
          var template = new esri.InfoTemplate("", "<b>Unique ID:</b> <br/> ${UNIQUEID} <br/><br/> <b>Address:</b> <br/> ${PROP_LOC} <br/><br/> <b>Owner of record:</b> <br/> ${OWNER_NAME} <br/><br/> <b>Block ID:</b> <br/> ${BLOCK} <br/><br/> <b>Lot ID:</b> <br/> ${LOT}");
          feature.setInfoTemplate(template);
        //else if (result.layerName === 'Building Footprints'){
          //var template = new esri.InfoTemplate("", "Parcel ID: ${PARCELID}");
          //feature.setInfoTemplate(template);
        return feature;
    map.infoWindow.setFeatures([ deferred ]);
    map.infoWindow.show(evt.mapPoint);
  dojo.ready(init);
</script>
