Basic Viewer (Javascript) on premise
1406
11-21-2011 08:52 AM
EricLacoursiere
New Contributor II
I would like to install the Basic Viewer on my webserver and use it along with my ArcGIS Server and ArcGIS Online web services only.
In the configuration's file, I can find the map key, but don't see where I can define my Content Directory's URL (.../ArcGIS/Mobile/Content/MobileWeb/Maps/) so the ID is related to my "local" json file instead of the ArcGIS Online hosted version.
My question: Can we use the Basic Viewer (and the others tempates) with the JSON configuration file or if it works only with the ArcGIS Online MapID? (If yes, how?)
Eric
KellyHutchins
Esri Frequent Contributor
Eric,
If I understand your question correctly then sure you can use the templates with a web map created via json. Here's an example that takes a web map, from the 'Create Web Map from JSON' developer sample and uses that with the Basic Viewer template. I just create the web map then set the web map as the configOptions.webmap value.
    <script type="text/javascript">
      dojo.require("dijit.dijit");
      dojo.require("dijit.dijit-all");
      dojo.requireLocalization("esriTemplate","template");
    </script>
    <script type="text/javascript" src="javascript/layout.js">
    </script>
     var configOptions;
      function init() {
       var webmap = {};
        webmap.item = {
          "title":"Soil Survey Map of USA",
          "snippet": "This map shows the Soil Survey Geographic (SSURGO) by the United States Department of Agriculture's Natural Resources Conservation Service.",
          "extent": [[-139.4916, 10.7191],[-52.392, 59.5199]]
        webmap.itemData = {
          "operationalLayers": [{
            "url": "http://server.arcgisonline.com/ArcGIS/rest/services/Specialty/Soil_Survey_Map/MapServer",
            "visibility": true,
            "opacity": 0.75,
            "title": "Soil Survey Map",
            "itemId": "204d94c9b1374de9a21574c9efa31164"
          "baseMap": {
            "baseMapLayers": [{
              "opacity": 1,
              "visibility": true,
              "url": "http://services.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer"
              "isReference": true,
              "opacity": 1,
              "visibility": true,
              "url": "http://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Reference_Overlay/MapServer"
            "title": "World_Terrain_Base"
          "version": "1.1"
        configOptions = {
          //The ID for the map from ArcGIS.com
         //webmap:"dbd1c6d52f4e447f8c01d14a691a70fe",
         webmap:webmap,
         //The id for the web mapping applciation item that contains configuration info - in most
         //cases this will be null.
          appid:"",
          //set to true to display the title
          displaytitle:true,
          //Enter a title, if no title is specified, the webmap's title is used.
          title:"",
          //Enter a description for the application. This description will appear in the left pane
          //if no description is entered the webmap description will be used.
          description: "",
          //Specify a color theme for the app. Valid options are gray,blue,purple,green and orange
          theme:'gray',
          //Optional tools - set to false to hide the tool
          //set to false to hide the zoom slider on the map
          displayslider:true,
          displaymeasure:true,
          displaybasemaps:true,
          displayoverviewmap:true,
          displayeditor:true,////When editing you need to specify a proxyurl (see below) if the service is on a different domain
          //Specify a proxy url if you will be editing
          proxyurl: "http://autumn/proxy/proxy.ashx",
          displaylegend:true,
          displaysearch:true,
          displaylayerlist:true,
          displaybookmarks:true,
....... more config stuff here
        initMap();
      dojo.addOnLoad(init);
    </script>
EricLacoursiere
New Contributor II
Hi Kelly,
Thanks for your quick response!
So, my goal is to host the JSON file on my ArcGIS Server Content (http://*****.com/ArcGIS/Mobile/Content/MobileWeb/Maps/)
And use the Basic Viewer with this JSON file:
http://apps.arcgis.com/hosted/OnePane/basicviewer/index.html?webmap=ad62846458d644a397d296127000dd99
I need to know where I specify my Server Content URL.
Cheers,
Eric
SureshRajamani
New Contributor II
I need to refer my local javascript api for this basic viewer.
But i m getting error while executing this line   dojo.requireLocalization("esriTemplate","template");
How to configure the Basic Viewer with local arcgis javascripr api in my web server.
roemhildtg
Occasional Contributor III
We were also looking for a configureable basic viewer to consume our on premise arcgis server resources, and we think that this will be exactly what we were looking for:
https://github.com/DavidSpriggs/ConfigurableViewerJSAPI
