Buffer results
8815
14
02-04-2015 01:15 PM
MayJeff
Just notice some issues on JSFiddle Edit fiddle - JSFiddle .  When I input this Parcel ID: 1931376038, and run 100 feet buffer. It shows more parcels outside the buffer ring. If I enter this parcel ID 193137602, and add this code like params.unionResults =true in order to combine buffer ring but still shows each single buffer rings.  How do you only show all parcels inside buffer ring and if search results are more than one, but only want to show one buffer ring instead of individual buffer ring around each parcels.  Thank you.
MayJeff
Robert,
I had my proxy setting this way too
          esriConfig.defaults.io.proxyUrl = "/proxy/proxy.ashx";
          esriConfig.defaults.io.alwaysUseProxy = true;
When run the rewrite code eventhough got results return for parcels after apply buffer.  See my attachments for error message I got.
The reason proxy showed like this esriConfig.defaults.io.proxyUrl = "/proxy/"; because from esri sample.  All the jsfiddle posted here are using their map services and I changed it to my own & use my own proxy setting too.  The first jsfiddle just got extra parcels results. Code is working.
Thank you.
RobertScheitlin__GISP
May Jeff,
   So are you good to go now? I can not tell from your reply if your issue is resolved. As I stated I tried Both of your fiddles codes and just added by proxy and they work fine.
MayJeff
Robert when you try my rewrite code, do you get any error message like that one I posted? I am not sure way still got error message - see above attachment files even though got results when apply buffer.
Thank you.
May Jeff,
  No errors. I also fixed several other things I saw in the code and updated to 3.13 API to use some of the great new stuff like geometryEngineAsync.  Here is my updates:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
  on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Buffer</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      overflow: hidden;
    #leftPane {
      color: #000;
      width: 250px;
      padding-bottom: 15px;
    #map {
      padding: 0;
    .details {
      font-size: 14px;
      font-weight: 600;
      padding-bottom: 20px;
    button {
      margin: 2px;
      cursor: pointer;
  </style>
  <script src="http://js.arcgis.com/3.13/"></script>
  <script>
    require([
          "esri/map",
          "esri/config",
          "esri/layers/FeatureLayer",
          "esri/tasks/query",
          "esri/symbols/SimpleLineSymbol",
          "esri/symbols/SimpleFillSymbol",
          "esri/graphic",
          "esri/graphicsUtils",
          "esri/geometry/geometryEngineAsync",
          "esri/tasks/GeometryService",
          "esri/Color",
          "dojo/on",
          "dojo/dom",
          "dijit/registry",
          "dojo/_base/array",
          "dojox/grid/DataGrid",
          "dojo/data/ItemFileReadStore",
          "dijit/form/Button",
          "dojo/parser",
          "dijit/layout/BorderContainer",
          "dijit/layout/ContentPane",
          "dojo/domReady!"
    ], function (
      Map, esriConfig, FeatureLayer, Query, SimpleLineSymbol, SimpleFillSymbol,
      Graphic, graphicsUtils, geometryEngineAsync, GeometryService,
      Color, on, dom, registry, arrayUtils, DataGrid, ItemFileReadStore, Button, parser) {
      var map, center, zoom;
      var grid, store;
      var graphic;
      var bufferGra;
      parser.parse();
      esriConfig.defaults.io.proxyUrl = "/Proxy/proxy.ashx";
      esriConfig.defaults.io.alwaysUseProxy = false;
      registry.byId("applyBufferP").on("click", applyBufferP);
      registry.byId("clearParcelGrid").on("click", clearParcelGrid);
      registry.byId("parcelSearch").on("click", queryParcels);
      registry.byId("intersectBuffer").on("click", intersectParcels);
      center = [-83.266, 42.568];
      zoom = 11;
      map = new esri.Map("map", {
        basemap: "streets",
        center: center,
        zoom: zoom
      var parcelUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/TaxParcelQuery/MapServer/0";
      var featureLayerParcel = new FeatureLayer(parcelUrl, {
        mode: FeatureLayer.MODE_SELECTION,
        visible: true,
        outFields: ["PARCELID", "SITEADDRESS", "OWNERNME1", "OWNERNME2", "RESYRBLT"]
      var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL, new SimpleLineSymbol(SimpleFillSymbol.STYLE_SOLID, new Color([100, 100, 100]), 2), new Color([0, 0, 255, 0.20]));
      featureLayerParcel.setSelectionSymbol(symbol);
      map.addLayer(featureLayerParcel);
      function queryParcels() {
        var queryParcels = new Query();
        queryParcels.where = "PARCELID LIKE '" + "%" + dom.byId("parcelText").value + "'";
        featureLayerParcel.selectFeatures(queryParcels, FeatureLayer.SELECTION_NEW, function (features, selectionMethod) {
          if (features.length > 0) {
            var parcelItems = dojo.map(features, function (feature) {
              return feature.attributes;
            var parcelData = {
              identifier: "PARCELID",
              items: parcelItems
            var parcelStore = new ItemFileReadStore({
              data: parcelData
            var parcelGrid = registry.byId("gridP");
            parcelGrid.on("rowclick", onRowClickHandler);
            parcelGrid.setStore(parcelStore);
            map.setExtent(graphicsUtils.graphicsExtent(featureLayerParcel.getSelectedFeatures()), true);
          } else {
            alert("No Parcels found!");
      function intersectParcels() {
        geometryEngineAsync.union(bufferGra).then(
          function (union) {
            var queryNew = new Query();
            queryNew.outFields = ["PARCELID", "SITEADDRESS", "OWNERNME1", "OWNERNME2", "RESYRBLT"];
            queryNew.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
            queryNew.geometry = union;
            queryNew.returnGeometry = true;
            featureLayerParcel.selectFeatures(queryNew, FeatureLayer.SELECTION_ADD, function (features, selectionMethod) {
              var items = dojo.map(features, function (feature) {
              var data = {
                items: items
              var store = new ItemFileReadStore({
                data: data
              var grid = registry.byId("parcelGrid");
              grid.on("rowclick", onRowClickHandler);
              grid.setStore(store);
              arrayUtils.forEach(features, function (feature) {
                graphic = new Graphic(feature.geometry, symbol);
                map.graphics.add(graphic);
        dijit.byId("dialogOne").show();
      function applyBufferP() {
        var graphics = featureLayerParcel.graphics;
        var selectedGeoms = graphicsUtils.getGeometries(graphics);
        var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
            new Color([0, 0, 255, 0.65]), 2
          new Color([0, 0, 255, 0.35])
        geometryEngineAsync.buffer(selectedGeoms, [100], GeometryService.UNIT_FOOT, true).then(
          function (geoms) {
            arrayUtils.forEach(geoms, function (geometry) {
              map.graphics.add(new Graphic(geometry, symbol));
            bufferGra = geoms;
      function onRowClickHandler(evt) {
        var clickedObjectf = evt.grid.getItem(evt.rowIndex).PARCELID;
        var selectedObjectf;
        var distance = 50;
        dojo.forEach(featureLayerParcel.graphics, function (graphicf) {
          if ((graphicf.attributes) && graphicf.attributes.PARCELID === clickedObjectf) {
            selectedObjectf = graphicf;
            return;
        if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Point') {
          var PointExtent = new esri.geometry.Extent({
            "xmin": selectedObjectf.geometry.x - distance,
            "ymin": selectedObjectf.geometry.y - distance,
            "xmax": selectedObjectf.geometry.x + distance,
            "ymax": selectedObjectf.geometry.y + distance,
            "spatialReference": {
              "wkid": 102100
          map.setExtent(PointExtent);
        } else if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Polygon') {
          var selectedParcel = selectedObjectf.geometry.getExtent();
          map.setExtent(selectedParcel.expand(3));
        } else if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Polyline') {
          var selectedStreetl = selectedObjectf.geometry.getExtent();
          map.setExtent(selectedStreetl.expand(3));
      function clearParcelGrid() {
        var newStore = new ItemFileReadStore({
          data: {
            idenitifer: "",
            items: []
        var grid = registry.byId("gridP");
        grid.setStore(newStore);
        document.getElementById('parcelText').value = '';
        featureLayerParcel.clearSelection();
        map.graphics.clear();
  </script>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;">
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:200px;" title="Search">
        Search by Parcel #:
        <input type="text" id="parcelText" value="1931376029" />
        <br>
        <button id="parcelSearch" data-dojo-type="dijit/form/Button" type="button" data-dojo-attach-point="button">Search</button>
        <button id="clearParcelGrid" data-dojo-type="dijit/form/Button" type="button" data-dojo-attach-point="button">Clear</button>
        <button id="applyBufferP" data-dojo-type="dijit/form/Button" type="button" data-dojo-attach-point="button">Buffer</button>
        <button id="intersectBuffer" data-dojo-type="dijit/form/Button" type="button">Show Parcels Intersecting Buffer</button>
        <table data-dojo-type="dojox/grid/DataGrid" jsid="gridP" id="gridP">
          <thead>
            <tr>
              <th field="PARCELID">Parcel ID</th>
              <th field="OWNERNME1">Owner 1</th>
              <th field="OWNERNME2">Owner 2</th>
              <th field="SITEADDRESS">Address</th>
              <th field="RESYRBLT">Year Built</th>
            </tr>
          </thead>
        </table>
      </div>
      <div id="dialogOne" data-dojo-type="dijit/Dialog" title="Selected Parcels">
        <div data-dojo-type="dijit/layout/ContentPane" title="Selected Parcels">
          <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="parcelGrid" id="parcelGrid" style="width: 375px; height: 600px" data-dojo-props="rowsPerPage:'100', rowSelector:'20px'">
            <thead>
              <tr>
              </tr>
            </thead>
          </table>
        </div>
      </div>
      <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;"></div>
    </div>
  </body>
MayJeff
Robert,
Your new code with clien-side buffer works so great!.  Thank you so much for it.
