Sorry, I think I'm a little confused. Trying to style a page using 3.16 of the API, I'd need a calcite.css and esri.css, which I don't think are included with any of calcite-web, calcite-bootstrap, of calcite-maps that I can find. There are the CDN versions....https://js.arcgis.com/3.16/esri/themes/calcite/dijit/calcite.css and https://js.arcgis.com/3.16/esri/themes/calcite/esri/esri.css , which work great and as expected. And there are the versions from building the 3.16 v of the Dojo JS API using Bower, Grunt, etc. etc (./esri/css/calcite/calcite.css, and ./esri/css/esri.css). These local versions don't really work that well, especially with the attribute inspector widget but also with some other minor differences. So if I'm to understand you correctly, are there some different css files to use in place of these, ones that are in calcite-web, calcite-bootstrap, or calcite-maps? I'm already using calcite-maps-arcgis-3.x.css, which is built from calcite-maps, and calcite-bootstrap.
Thanks!
