Call function from Popup window
6479
11
12-08-2015 12:18 PM
RyanSellman
Occasional Contributor II
Hello All,
Does anyone have an example of how to call a function from inside a popup window?  I've been digging around the forums and haven't had much luck in finding a sample of what I am trying implement.  Right now, I have a Popup Template set up that shows basic attributes for the selected feature and also provides links to various resources regarding that selected feature.  See the image attached.
Below the Recorded Documents link, I'd like to add an "Open Old Tax Map Image" link that calls a function instead of opening a link.  I have tried a handful of things including using code from this sample ​but I can't get anything to do exactly what I have described.  Does anyone have an idea as to how I can accomplish this?
Any help is appreciated!
Ryan
RobertScheitlin__GISP
Ryan,
  Then you just hide the link if it is not the layer you want it to show on:
Link will only show for the "KS_FIELD_OUTLINES_SPRING2005_GEONAD27" layer and not the census layers
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Extend Popup</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
  <style>
    html,
    body,
    #mapDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script src="https://js.arcgis.com/3.15/"></script>
  <script>
    var map;
    require([
        "esri/map",
        "esri/dijit/Popup",
        "esri/InfoTemplate",
        "esri/SpatialReference",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/graphic",
        "dojo/dom-construct",
        "dojo/query",
        "dojo/on",
        "dojo/dom-attr",
        "dojo/dom",
        "dojo/dom-style",
        "esri/Color",
        "dojo/domReady!"
      ], function (
      Map,
      Popup,
      InfoTemplate,
      SpatialReference,
      ArcGISDynamicMapServiceLayer,
      SimpleLineSymbol,
      SimpleFillSymbol,
      Graphic,
      domConstruct,
      query,
      on,
      domAttr,
      dom,
      domStyle,
      Color
      var sls = new SimpleLineSymbol("solid", new Color("#444444"), 3);
      var sfs = new SimpleFillSymbol("solid", sls, new Color([68, 68, 68, 0.25]));
      var popup = new Popup({
        fillSymbol: sfs,
        lineSymbol: null,
        markerSymbol: null
      }, domConstruct.create("div"));
      map = new Map("mapDiv", {
        basemap: "topo",
        center: [-94.75290067627297, 39.034671990514816], // long, lat
        zoom: 12,
        sliderStyle: "small",
        infoWindow: popup
      var link = domConstruct.create("a", {
        "class": "action mylink",
        "id": "statsLink",
        "innerHTML": "Action Link Test", //text that appears in the popup for the link
        "href": "javascript: void(0);"
      }, query(".actionList", window.map.infoWindow.domNode)[0]);
      //when the link is clicked register a function that will run
      on(link, "click", writeToConsole);
      on(popup, "selection-change", checkLayer);
      function checkLayer() {
        var feat = popup.getSelectedFeature();
        if(feat && feat._layer && feat._layer.name === "KS_FIELD_OUTLINES_SPRING2005_GEONAD27"){
          domStyle.set(query(".actionList > .action.mylink", window.map.infoWindow.domNode)[0], "display", "") ;
        }else{
          domStyle.set(query(".actionList > .action.mylink", window.map.infoWindow.domNode)[0], "display", "none");
      var _countyCensusInfoTemplate = new InfoTemplate();
      _countyCensusInfoTemplate.setTitle("<b>Census Information</b>");
      var _blockGroupInfoTemplate = new InfoTemplate();
      _blockGroupInfoTemplate.setTitle("<b>Census Information</b>");
      var _censusInfoContent =
        "<div class=\"demographicInfoContent\">" +
        "<div class='demographicNumericPadding'>${AGE_5_17:formatNumber}</div><div class=\"demographicInnerSpacing\"></div>people ages 5 - 17<br>" +
        "<div class='demographicNumericPadding'>${AGE_40_49:formatNumber}</div><div class=\"demographicInnerSpacing\"></div>people ages 40 - 49<br>" +
        "<div class='demographicNumericPadding'>${AGE_65_UP:formatNumber}</div><div class=\"demographicInnerSpacing\"></div>people ages 65 and older" +
        "</div>";
      _countyCensusInfoTemplate.setContent("Demographics for:<br>${NAME} ${STATE_NAME:getCounty}, ${STATE_NAME}<br>" + _censusInfoContent);
      _blockGroupInfoTemplate.setContent("Demographics for:<br>Tract: ${TRACT:formatNumber} Blockgroup: ${BLKGRP}<br>" + _censusInfoContent);
      var _oilAndGasInfoTemplate = new InfoTemplate();
      _oilAndGasInfoTemplate.setTitle("<b>Oil and Gas data</b>");
      var _oilAndGasInfoContent =
        "Gas production: ${PROD_GAS}<br>Oil production: ${PROD_OIL:formatNumber}" +
        "</div>";
      _oilAndGasInfoTemplate.setContent("${FIELD_NAME} production field<br>" +
        _oilAndGasInfoContent);
      var demographicsLayerURL = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer";
      var demographicsLayerOptions = {
        "id": "demographicsLayer",
        "opacity": 0.8,
        "showAttribution": false
      var demographicsLayer = new ArcGISDynamicMapServiceLayer(demographicsLayerURL, demographicsLayerOptions);
      demographicsLayer.setInfoTemplates({
        1: { infoTemplate: _blockGroupInfoTemplate },
        2: { infoTemplate: _countyCensusInfoTemplate }
      demographicsLayer.setVisibleLayers([1, 2]);
      map.addLayer(demographicsLayer);
      var oilAndGasLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapServ...", {
        "id": "oilAndGasLayer",
        "opacity": 0.75
      oilAndGasLayer.setInfoTemplates({
        0: { infoTemplate: _oilAndGasInfoTemplate }
      map.addLayer(oilAndGasLayer);
      function writeToConsole(evt) {
        console.info("Hello Word");
  </script>
</head>
<body>
  <div id="mapDiv"></div>
</body>
</html>
Ryan,
  I am not sure why you can not get that sample to work. Here is that sample and the Add two dynamic maps sample put together and the action link calls a function to write to the console just fine.
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mapDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    var map;
    require([
        "esri/map",
        "esri/dijit/Popup",
        "esri/graphic",
        "dojo/query",
        "dojo/on",
        "dojo/dom-attr",
        "dojo/dom",
        "esri/Color",
        "dojo/domReady!"
      ], function (
      Map,
      Popup,
      InfoTemplate,
      SpatialReference,
      SimpleLineSymbol,
      SimpleFillSymbol,
      Graphic,
      domConstruct,
      query,
      on,
      domAttr,
      dom,
      Color
        fillSymbol: sfs,
        lineSymbol: null,
        markerSymbol: null
        basemap: "topo",
        zoom: 12,
        infoWindow: popup
        "class": "action",
        "id": "statsLink",
        "</div>";
        "</div>";
        "opacity": 0.8,
        "opacity": 0.75
  </script>
</head>
<body>
</body>
</html>
RyanSellman
Robert,
Thank you for the response.  In my project, I was able to get the GP population sample to work but I don't want the link to appear in the actions list section of the popup, rather it should be right under the Recorded Documents link, only in the Parcel popup template  My map click event queries a handful of services all with separate popup templates.  This link/function needs to be available only in the Parcel popup template, not in the actions list section for all templates.
Ryan
Ryan,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mapDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    var map;
    require([
        "esri/map",
        "esri/dijit/Popup",
        "esri/graphic",
        "dojo/query",
        "dojo/on",
        "dojo/dom-attr",
        "dojo/dom",
        "dojo/dom-style",
        "esri/Color",
        "dojo/domReady!"
      ], function (
      Map,
      Popup,
      InfoTemplate,
      SpatialReference,
      SimpleLineSymbol,
      SimpleFillSymbol,
      Graphic,
      domConstruct,
      query,
      on,
      domAttr,
      dom,
      domStyle,
      Color
        fillSymbol: sfs,
        lineSymbol: null,
        markerSymbol: null
        basemap: "topo",
        zoom: 12,
        infoWindow: popup
        "id": "statsLink",
        }else{
        "</div>";
        "</div>";
        "opacity": 0.8,
        "opacity": 0.75
  </script>
</head>
<body>
</body>
</html>
RyanSellman
Robert,
That's great!  I never thought of hiding the link in the templates it does not need to be in.  However, given the nature of the function I am calling, it would be ideal have the link below the two others already present (Property Record Card & Recorded Documents) and not in the actions list section next to "Zoom to".  Do you know of a way to get the link in the same area as the others?  If not, no biggie.  I can certainly make the sample you provided me with work.
Thank you again for all your help!
Ryan
Ryan,
   I currently have not tried to call a function from the popup content section, so I don't have a sample for that.
RyanSellman
No worries at all!  I will make your sample work.  Thanks for answering my initial question.
Ryan
RyanSellman
Hi Robert,
I know I marked this thread as answered, but I am still having some issues implementing the code you supplied.  Creating a link and calling a function when that link is clicked is no longer the issue.  Rather, my problem now occurs after the pop up is shown and set (after the map click event).  When I try to click the map again, with the popup window still open, I get a message in the console saying "Cannot read property '_layer' of undefined".  The same is happening with the sample you posted above.  Any ideas why this is happening?
Ryan
Ryan,
   Sure just use this updated function:
        }else{
RyanSellman
That's it!  Thank you so much!  If you get a chance, could you describe what was happening?
Thank you again!
Ryan
