Is there a way to find out why a submitjob, from Javascript, for an asynchronous service has failed? It works fine in the endpoint of the service. The three parameters are string inputs. I have the jobid number. Can I use that job number to figure out the error? Below is my parameter input. I have a feeling this may be incorrect. HELP! 🙂
var params = {
"inRaster": "gdd100",
"codeField": "gdd100_AN",
"strRemap": "0,800,1,800,900,2,900,1000,3,1000,1500,4"
