Can Accessor not be used as Singleton?
1225
03-17-2017 12:26 PM
BenFousek
I'm playing around with Accessor and trying to return a Singleton but requiring the module anytime after first require on booting the app just returns an Object.
// returns Singleton
define([
  'dojo/_base/declare',
  'dojo/Stateful',
  'dojo/Evented'
], function (
  declare,
  Stateful,
  Evented
  var _instance = null;
  var Model = declare([Stateful, Evented], {
  // stuff
  if (!_instance) {
    _instance = new Model();
  return _instance;
// returns Object
define([
  'esri/core/Accessor',
  'dojo/Evented'
], function (
  Accessor,
  Evented
  var Model = Accessor.createSubclass([Evented], {
  // stuff
  if (!_instance) {
  return _instance;
deleted-user-iPdcWUgWcsoy
Perhaps you find further informations in this link for real singletons (entry by "JonS"). We use it in our applications.
http://stackoverflow.com/questions/4334437/dojo-singleton-or-at-least-static-method-variable
Your second sample code can look like this.
// returns Object
define([
  './Singleton',
  'dojo/Evented'
], function (
  Accessor,
  Evented
  var Model = Singleton(Accessor.createSubclass([Evented], {
  // stuff
  return Model.getInstance(); // or just return the singleton
// returns Object
define([
  './Singleton',
  'dojo/Evented'
], function (
  Accessor,
  Evented
  // stuff
BenFousek
Thanks for the reply Martin. That's more elegant.
My problem was configuring dojo and booting the app in the same require(). Dojo didn't like the relative path when requiring the model after boot.
Moved dojo config to its own require to fix problem.
