Can measurement tool graphics be persisted?
995
05-12-2017 12:11 PM
DaveSouthern
New Contributor II
I have a requirement from the customer to persist measurements made by the measurement tool i.e. have multiple measurement lines on the map simultaneously and be able to save these between sessions.  I checked out the documentation links below but haven't been able to see how this could be done.  It doesn't appear that the measurement tool has a layer associated with it, but maybe I'm missing it.
Is there a way to do what I'm thinking about - even if I have to kludge my way into it somehow?
ThomasSolow
Occasional Contributor III
My guess would be that you can listen to the 'measure-end' event on the dijit, which will give you access to the result of the measurement and a geometry.
From here, you could take that geometry and create your own graphic from it.  You could use the measurement result (also from the measure-end event) as an attribute on that graphic.  This graphic can then be added to a feature layer (probably a polyline feature layer) in order to persist it.  You can add a label class to the feature service backing up that feature layer that looks at the attribute that represents the measurement result and applies it as a label.
ThomasSolow
DaveSouthern
New Contributor II
I was thinking something along those lines, but wanted to make sure I wasn't overlooking something.
DaveSouthern
New Contributor II
OK.  So now I'm trying to find a javascript example of how to wire up the measure-end event.  Can you point me to one?
ThomasSolow
Here's a jsbin showing how to tap into the event: JS Bin - Collaborative JavaScript Debugging
DaveSouthern
New Contributor II
Thanks Thomas - I appreciate the help.
