New to the API and javascript. Any help would be appreciated. Thanks
<!DOCTYPE html>
<html>
<head>
<title>Create a Web Map</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.14/esri/css/esri.css">
<style>
html,body,#mapDiv,.map.container{
padding:0;
margin:0;
height:100%;
</style>
<script>var dojoConfig = { parseOnLoad:true };</script>
<script src="http://js.arcgis.com/3.14compact/"></script>
<script>
var map,
webmapId = "dd487118ba2f4597a0ebc2bcaafb3fb4";
require([
"esri/map",
"esri/graphic",
"esri/arcgis/utils",
"dojo/domReady!"
], function(Map, graphic, arcgisUtils){
arcgisUtils.createMap(webmapId, "mapDiv").then(function (response) {
map = response.map;
//show cursor as pointer when hovered over clickable graphic/feature
map.on('load', function() {
graphicLayer.enableMouseEvents();
graphicLayer.on("mouse-over", function(){
map.setMapCursor("pointer");
graphicLayer.on("mouse-out", function(){
map.setMapCursor("default");
</script>
</head>
<body>
<div id="mapDiv"></div>
</body>
</html>
