Saloni,
Sure the "ESRI World Geocoder" is just a API default string for the search widget. So just add the following require and var and then this one line of code.
Require: "dojo/i18n!esri/nls/jsapi",
Var: esriBundle
esriBundle.widgets.Search.main.esriLocatorName = "something new";
