Cityworks Map Error
714
12-18-2018 01:20 PM
TimShomberg
We're having intermittent issues in our Cityworks application, both might be related to this attached error.
It seems to be an error in authentication. What is JS.ARCGIS.COM being called for? What are the expected inputs and outputs for  this call?
This error has appeared both when the map is trying to render, and when trying to save assets from the map to a work order.
Attached is an example of the error.
