Color in FeatureTable Grid
281
12-14-2021 02:39 PM
YogaYoda
I have a FeatureTable that I need the color of grids in a column to be colored either blue or yellow depending on the value within the grid. For example if the number is between 1-5 the color should be blue, otherwise if it is between 6-10 the color of the grid should be yellow. Is it possible to change the color of the individual grid with css (or other) based on this type of condition? Or would the entire row have to be either blue or yellow, which is fine.
Any assistance would be appreciated.
Thanks.
