ContentPane region attribute not working
1424
07-01-2011 10:50 AM
Wei-HsinFu
I am new to the API and get stuck on something that seems very straightforward.  I have three content panes in a bordercontainer.  I use the region attribute to specify their locations on the page, but the specs seem to be ignored by the browser (tried on FireFox so far). No matter what locations I specified the browser always place the three content panes from top to bottom in the order the <div> elements appear in the HTML document.  Any suggestions? Here is my HTML doc.  Thanks a lot.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
    <head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
        <title>Ancient Theaters in Italy</title>
        <link href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.3/js/dojo/dijit/themes/claro/claro.css" rel="stylesheet" type="text/css">
        <style>
            #titlePane {
                width: auto;
                height: 50px
            #timesliderPane {
                width: 60px;
                height: 50px;
                padding: 5px
        </style>
        <script type="text/javascript" data-dojo-config="parseOnLoad: true; isDeBug: true"
        </script>
        <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.3">
        </script>
        <script type="text/javascript">
            dojo.require("dijit.layout.ContentPane")
            dojo.require("dijit.layout.BorderContainer")
            dojo.require("dijit.layout.AccordionContainer")
            dojo.require("esri.map");
            dojo.addOnLoad(init);
            var map;
            function init(){
                map = new esri.Map("mapPane");
                var basemapURL = "https://arcgis.its.carleton.edu/ArcGIS/rest/services/ItalyTheaters/MapServer"
                var basemap = new esri.layers.ArcGISDynamicMapServiceLayer(basemapURL);
                map.addLayer(basemap);
        </script>
    </head>
    <body class="claro">
        <div id="pageContainer" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'">
            <!-- TOP TITLE PANE-->
            <div id="titlePane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'">
                <h1 align="center">Ancient Theaters in Italy</h1>
            </div>
            <!--CENTER MAP PANE-->
            <div id="mapPane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'" style="width:900px; height:600px">
            </div>
            <!--BOTTOM TIME SLIDER PANE-->
            <div id="timesliderPane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'right'">
                Time slider here
            </div>
        </div>
    </body>
</html>
HemingZhu
    <head>
        <style>
            #titlePane {
                width: auto;
                height: 50px
            #timesliderPane {
                width: 60px;
                height: 50px;
                padding: 5px
        </style>
        </script>
        </script>
            var map;
            function init(){
        </script>
    </head>
            </div>
            </div>
                Time slider here
            </div>
        </div>
    </body>
</html>
In BorderContainer layout, top, center, bottom only honor height style not width; left and right panel only honor width style. See Attachment
Wei-HsinFu
Thank you for taking your time to help me.  It solved my problem.  Thanks again.
