Custom DynamicLayer
252
04-19-2024 07:21 AM
Wade
New Contributor III
Can this method also be used to customize things like MapImageLayer to read MapServer?
 const CustomWMSLayer = BaseDynamicLayer.createSubclass({
          properties: {
            mapUrl: null,
            mapParameters: null
          // Override the getImageUrl() method to generate URL
          // to an image for a given extent, width, and height.
          getImageUrl: function (extent, width, height){
            const urlVariables = this._prepareQuery(this.mapParameters, extent, width, height);
            const queryString = this._joinUrlVariables(urlVariables);
            return this.mapUrl + "?" + queryString;
          // Prepare query parameters for the URL to an image to be generated
          _prepareQuery: function (queryParameters, extent, width, height) {
            const wkid = extent.spatialReference.isWebMercator ? 3857 : extent.spatialReference.wkid;
            const replacers = {
              width: width,
              height: height,
              wkid: wkid,
              xmin: extent.xmin,
              xmax: extent.xmax,
              ymin: extent.ymin,
              ymax: extent.ymax
            const urlVariables = this._replace({}, queryParameters, replacers);
            return urlVariables;
          // replace the url variables with the application provided values
          _replace: (urlVariables, queryParameters, replacers) => {
            Object.keys(queryParameters).forEach((key) => {
              urlVariables[key] = Object.keys(replacers).reduce((previous, replacerKey) => {
                return previous.replace("{" + replacerKey + "}", replacers[replacerKey]);
              }, queryParameters[key]);
          // join the url parameters
          _joinUrlVariables: (urlVariables) => {
            return Object.keys(urlVariables).reduce((previous, key) => {
              return previous + (previous ? "&" : "") + key + "=" + urlVariables[key];
