Attached is a sample that shows how to make the print button show up in your fiddle and also how to add a print icon.Here are details on the fixes:
And in the sample I attached to my previous email if you don't want the text to display set lines 78-90 equal to an empty string. The problem with setting the printout to an empty string is that you won't have anything to click on when the print is complete because there won't be any text to display for the printout hyperlink.
esriBundle.widgets.print.NLS_print = "";
esriBundle.widgets.print.NLS_printing = "";
esriBundle.widgets.print.NLS_printout= "";
Just wanted to drop back and say thanks again, your solutions worked perfectly! Thanks Kelly and to the rest of the great folks here.
Hello Kelly
I implemented your example code in my app. I am using the proxy provided by ESRI on GitHub in my app because I use secured layers. The problem I have is that Print widget does not work when I using the proxy. Without the proxy I only can load the basemap but the Print Widget works. Can you help me please,
Thank you
Otto
