deck.gl legend
960
02-17-2022 02:23 PM
shaileshgavathe
Occasional Contributor II
Is there a way to display deck.gl based layers Legend under Legend Widget ?
Example one below. Can the legend display a renderer for it?
https://developers.arcgis.com/javascript/latest/sample-code/custom-lv-deckgl/
2 Solutions
KristianEkenes
Currently, custom layers and renderers are not supported by the Legend widget because there isn't a clear schema or contract between a custom layer and an out-of-the-box widget like Legend. You would need to create your own legend in these scenarios.
shaileshgavathe
Thank you @KristianEkenes . We will probably have to make one custom legend. Thanks again.
KristianEkenes
shaileshgavathe
