Hello,
We are trying to display a layer on a map using a LayerList Widget via the 3.25 version of the API. We have been able to successfully display the layer itself in the widget and on the map but are having trouble with being able to show labels for the layer. We see in the list of fields that the field name "PIN" exists but all our efforts to get the labels to display are coming up short. Our code is below. Any help will be much appreciated.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Parcel Details</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.25/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.25/esri/css/esri.css">
<style>
html, body, .container, #map {
height:100%;
width:100%;
margin:0;
padding:0;
margin:0;
font-family: "Open Sans";
#map {
padding:0;
#layerListPane{
width:25%;
.esriLayer{
background-color: #fff;
.esriLayerList .esriList{
border-top:none;
.esriLayerList .esriTitle {
border-bottom:none;
.esriLayerList .esriList ul{
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="https://js.arcgis.com/3.25/"></script>
<script>
require([
"esri/map",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/dijit/LayerList",
"esri/urlUtils",
"esri/layers/LabelClass",
"esri/layers/LayerDrawingOptions",
"esri/symbols/TextSymbol",
"dojo/domReady!"
], function (
Map,
ArcGISDynamicMapServiceLayer,
LayerList,
urlUtils,
LabelClass,
LayerDrawingOptions,
TextSymbol
urlUtils.addProxyRule({
urlPrefix: "www.gis.bocc.co.st-johns.fl.us",
proxyUrl: "<The URL to our ESRI Proxy Server comes here>"
var map = new Map("map", {
basemap: "topo",
center: [-81.312431, 29.901243],
zoom: 17,
sliderStyle: "small",
showLabels : true
map.on("load", function(){
var point = new esri.geometry.Point({ 'x': -81.312431, 'y': 29.901243, 'spatialReference': { 'wkid': 4326 } });
var infoSymbol =
new esri.symbol.PictureMarkerSymbol({
'angle':0,
'xoffset':0,
'yoffset':12,
'type':'esriPMS',
'url':'https://static.arcgis.com/images/Symbols/Basic/YellowStickpin.png',
'contentType':'image/png',
'width':24,
'height':24});
map.graphics.add(new esri.Graphic(point,infoSymbol));
var stJohnsCountyParcelLayer = new ArcGISDynamicMapServiceLayer("http://www.gis.bocc.co.st-johns.fl.us/sjcgis/rest/services/Parcel/MapServer", {
"id": "stJohnsCountyParcelLayer",
"showAttribution": false,
"showLabels": true
var optionsArray = [];
var drawingOptions = new LayerDrawingOptions();
var labelClass = new LabelClass({
labelExpression: '[' + "PIN" + ']',
labelPlacement: 'esriServerPolygonPlacementAlwaysHorizontal',
symbol: new TextSymbol()
drawingOptions.labelingInfo = [labelClass];
drawingOptions.showLabels = true;
optionsArray[0] = drawingOptions;
stJohnsCountyParcelLayer.setLayerDrawingOptions(optionsArray);
stJohnsCountyParcelLayer.show();
map.addLayer(stJohnsCountyParcelLayer);
var myWidget = new LayerList({
map: map,
layers: [{
layer: stJohnsCountyParcelLayer,
id: "St. Johns County Parcels",
showSubLayers: true
}, "layerList");
</script>
</head>
<body class="claro">
<div class="container" data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline',gutters:false">
<div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
<div id="layerList"></div>
</div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
</div>
</body>
</html>
Thanks.
