Dojox line chart - what can I do to keep from markers from getting cut off?
5186
9
04-28-2014 01:44 PM
TracySchloss
I have a dojox line chart that's populated from an identifyTask.  I'm pushing the results into an array, which is the input for my plot series.  I'm having a hard time searching out documentation on this, but I was able to get pretty far along with some trial and error.  The chart looks the way I want, except that the markers on the first and last values are cut off and I don't like the way it looks.  I'm looking for a parameter I can put on the X axis to prevent this.  Or maybe I need a better calculation to define the min and max on the axis so the markers fall a bit farther inside the very edge?
My data has multiple years worth of information for each polygon.  The layers in the service are named so the last 4 characters are always the year.  I'm using an identify on the center of the polygon.  This is my results handler
         function getStatsHandler(results){//formats the results for line chart, then generates it
              stats.length = 0;
              yearList.length = 0;
              rateList.length = 0;
              var year;
              domConstruct.empty("chartDiv");
              for (i=0;i<results.length;i++) {
                var lyrResult = results;
                itemLength = lyrResult.layerName.length;
                yearPos = itemLength - 4;
                year = lyrResult.layerName.substr(yearPos, 4);
                var rate = lyrResult.feature.attributes.RATE;
                yearList.push({value: i+1, text:year});
                rateList.push(parseFloat(rate));
               rateList.sort(function(a,b){return a-b});
               var maxVal = rateList[rateList.length -1];
               maxVal = Math.round(maxVal);
               var axisMax =  (parseInt(maxVal/10)+1)*10;
          var lineChart = new Chart2D("chartDiv", {
            title: currentCounty + "</br>" + title + " Rates" ,
            titlePos:"bottom",
            titleGap: 12,
            titleFont: "normal normal normal 13pt Arial",
          lineChart.addPlot("default", {
            type: "Lines",
            markers: true,
            hAxis: "x",
            vAxis: "y"});
          lineChart.addAxis("x", {
            title:"Rates by Year",
            titleOrientation:"away",
            labels: yearList,
            font: "normal normal normal 9pt Arial",
            majorLabels: true,
            minorTicks: false,
            minorLabels: false,
             microTicks: false });
          lineChart.addAxis("y", {
            title:rateNote,
            vertical: true,
            fixLower: "major",
            fixUpper: "major",
            min: 0,
            max: axisMax,
            minorTicks: false,
            minorLabels: true});
            //{vertical: true, min: 0, max: axisMax});
          lineChart.addSeries("Series 1", rateList, {
              stroke: { color: "red", width: 2 }
           var tip = Tooltip(lineChart, "default", {
              text : function(o) {
                var yr = yearList[o.x].text;
                var yrList = parseInt(yr) - 1;
                return ( yrList +'<br>' + o.y );
          lineChart.render();
Everything works in this code except for the cropped markers.  Even the online examples for line charts look to have this problem too, but I'm hoping for a workaround anyway.
TracySchloss
I figured it out!  If you increase the length of the x Axis slightly, it won't cut the point off.  I did this in my example by adding 0.5
   var xAxisMax = years.length + 0.5;  //extends the X axis so it doesn't crop off the point
TracySchloss
Cesar_AugustoRibeiro
Hey, I'm in the same situation and I liked the solution, but didn't understand where did you use that xAxisMax variable; could you show? Thanks
TracySchloss
I don't think I've touched this since I posted it, but in my code it looks like I added right after the line  where I set the xAxis
   var xAxisMax = years.length + 0.5; //where years is the array holding the data from my identify, extends the X axis so it doesn't crop off the point
Then you add one more parameter in the X axis definition of the lineChart:
        max: xAxisMax,
In my post, I have data by year, so 'years' is the name of my array.    You'll need to study your data to determine what variable you have to work with.
I have data by month/year and tried to add +0.5 to max too, but didn't work very well. See before and after prints:
Before:
After:
See that the first marker is still cropped and the top y axis one (value above 50) is too (this one I know that is not solved with max in x axis).
TracySchloss
I think you can calculate the maximum value of the y axis too.  Have you tried another constant besides 0.5?  That was a value that worked for me, but your range of values might require something different.
Here are the links I used when I was doing my research:
Customizing charts using Dojo
| A Beginner’s Guide to Dojo Charting with AMD, Part 1 of 2 | Blog | SitePen
| Dive Into Dojo Charting Again | Blog | SitePen
Maybe you'll find something useful.
Thanks Tracy, I got it working with the explanation of Scaler in your first link
TracySchloss
The graphic looks right, but are those the correct values on your Y axis?  They're nothing like your original numbers.
There seems to be quite a lot you can do with this chart object, but almost no documentation to go along with it.
Hey Tracy, yes, they are correct. My data are dynamic, so I calculated max similarly the way you did, with some gap to avoid the cropping.
I agree with your comments about documentation, I felt lack of updated explanative docs with rich samples.
NMWater
New Contributor III
Is it possible to do this with Media Infos in the popup template? I'm trying to add an x-axis to my data.
I have a counties layer with different years of data. Please advice!
Here are some snips of my results.
Thanks for all your help!
