DOM "stroke-width" attribute returns undefined in IE. Works in all other browsers.
793
6
05-24-2012 07:29 AM
AR
New Contributor III
this.line = this.obj.graphics[gfx].getDojoShape().getEventSource();                                                      $(this.line).attr("stroke-width")
This code returns the stroke-width value from the DOM element on a line on my map.
If I use alert() to capture the object in IE 7/8, it displays as undefined. In firebug for Firefox/Safari/Chrome, they all display the correct value.
Here is the code I've written so far (sorry it's a bit messy, I use jQuery for DOM manipulation, instead of destroying/adding new objects as dojo does):
var legendPane = $('div#legendPane')  $(legendPane).on("mouseenter mouseleave", "table.esriLegendLayer > tbody > tr", function(evt){         this.obj = $(this).data()                  if(typeof(this.obj) == "object"){             if( evt.type == "mouseenter"){                 for(gfx in this.obj.graphics){                     if (this.obj.graphics[gfx].geometry.type == "polyline"){                         try{                             this.line = this.obj.graphics[gfx].getDojoShape().getEventSource();                             ////////////////////////////////////////                                                         ///////displays 'undefined' in IE/////                                                         ///////////////////////////////////////                                                          alert($(this.line).attr("stroke-width"))        $(this.line).attr("stroke-width") == 2 ? $(this.line).attr("stroke-width", "8") : null;                         }catch (err){}                                                     }else if (this.obj.graphics[gfx].geometry.type == "point") {                         try {                             this.point = this.obj.graphics[gfx].getDojoShape().getEventSource();                             $(this.point).attr("r") == "8" ? $(this.point).attr("r", "13") : null;                              $(this.point).attr("r") == "2.5" ?  $(this.point).attr("r", "4") : null;                                  } catch (err) {}                         }                 }             }else if.....
derekswingley1
Rather than digging into the svg or vml properties, can you swap out the graphic's symbol using setSymbol()?
derekswingley1
What are you trying to do?
Mixing and matching jQuery and dojo methods complicates things...if you can describe specifically what you're trying to do we might be able to come up with a cleaner solution.
AR
New Contributor III
Derek, here's what I'm trying to accomplish:
I'm using the Legend Dijit. When a user hovers over an item in the Legend Dijit (see attached), the corresponding map graphic becomes highlighted, or rather, it's stroke size increases.
Step-by-step:
(1) ...if a user mouseEnters on an item in the Legend Dijit
  if( evt.type == "mouseenter"){....
(2) ...loop over the map graphics
for(gfx in this.obj.graphics){....
(3)...and, if this graphic is a polyline
if (this.obj.graphics[gfx].geometry.type == "polyline"){...
(4)...grab the polyline's corresponding DOM element:
(5)...use jQuery's attr() method to access this DOM element's "stroke-width" value
 this.stroke = $(this.line).attr("stroke-width")
Step 5 is the problem: this.stroke in IE 7/8 always returns undefined. Firefox/Chrome/Safari all return a value.
I realized Step 5 is the problem by using alert(this.stroke) in IE 7/8, which pops up as "undefined". All other browsers display a value.
Firefox.png is what is supposed to occur (notice the polyline's increased stroke-width, when I hover on the legend dijit item (highlighted in dark grey)).
IE.png is what is not supposed to occur (notice the polyline stroke does not increase)
Hope this helps,
Aaron
JeffPace
IE <8 uses vml, and i believe the attribute is strokeweight, not stroke width
so (5) will need to become
 if(dojox.gfx.renderer==="vml"){
 this.stroke = $(this.line).attr("stroke-weight")
}else{
I am not totally sure its stroke weight, going off http://msdn.microsoft.com/en-us/library/documentformat.openxml.vml.line.strokeweight
if you inspect it in IE's developer toolkit you should see the css property.
derekswingley1
AR
New Contributor III
@Jeff: I spent a solid hour digging through vml properties (which was my first notion to try, also), but found it to be too much work. Thanks for your suggestion.
@Derek: I was weary of using setSymbol() at first, since similar methods like setWidth() and setStroke require you to refresh() the graphics layer to see changes , which terribly degrades IE 7/8 performance. However, much to my surprise setSymbol() does not require a refresh()!! Thanks for your help.
Here's the finished few lines:
 if( evt.type == "mouseenter"){//...if the event is mouseenter//
  for(gfx in this.obj.graphics){//...loop the map graphics//
        if (this.obj.graphics[gfx].geometry.type == "polyline"){//...if the graphic is a polyline//
                                  this.gfx = this.obj.graphics[gfx]//...create a new reference for it//
                                  if(this.gfx.symbol.width == 2){//....by default, the polyline's width is set to 2//
                                           this.newSymbol = new esri.symbol.SimpleLineSymbol(this.gfx.symbol.style, this.gfx.symbol.color,8)//....create our new symbol with a new width of '8'//
                                           this.gfx.setSymbol(this.newSymbol) //...set our newSymbol to this graphic//
Derek and Jeff, thank you for your help!
derekswingley1
Glad we could help!
