Edit stand-alone feature service table using Javascript
189
3 weeks ago
MatthewDriscoll
MVP Alum
Is it possible to edit a stand-alone table from a feature service with the Javascript API?  I can do it using online and experience builder, but cannot figure it out using just the native Javascript API.  Anyone have an example on how it's done?  I am not trying to add it to the map/view or anything like that, just accessing the information to be edited.
This is the error I get:
Failed to resolve layer view (layer title: 'n', id: '####') f {name: 'featurelayerview:table-not-supported', details: {…}, message: "table feature layer can't be displayed"}
Sage_Wall
Using the FeatureTable widget with editing enabled is probably the easiest way, but applyEdits should work too.
https://codepen.io/sagewall/pen/jORvOeJ
Sage_Wall
MatthewDriscoll
MVP Alum
This is using a portal item, I can get that to work.  It's a feature service where the issue is.
User error.  Thanks for the help!
