Edit Toolbar and Measure tool bar not working together. When one is activated it messes up the other. Any suggestions?
<!DOCTYPE html>
<html>
<head>
<title>Edit Tools</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.26/dijit/themes/nihilo/nihilo.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.26/esri/css/esri.css">
<style>
html, body, #mainWindow {
font-family: sans-serif;
height: 100%;
width: 100%;
html, body {
margin: 0;
padding: 0;
#mainWindow {
visibility: hidden;
</style>
<script ></script>
<script>
var map, editToolbar;
require([
"esri/map",
"esri/toolbars/edit",
"esri/graphic",
"esri/dijit/Measurement",
"esri/geometry/Point",
"esri/geometry/Polyline",
"esri/geometry/Polygon",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/TextSymbol",
"dojo/_base/event",
"dojo/parser",
"dojo/dom",
"dojo/dom-style",
"dijit/registry",
"dijit/Menu",
"dijit/form/ToggleButton",
"dijit/form/DropDownButton",
"dijit/CheckedMenuItem",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/domReady!"
], function(
Map, Edit, Graphic,Measurement,
Point, Polyline, Polygon,
SimpleLineSymbol, SimpleFillSymbol, TextSymbol,
event, parser, dom, domStyle, registry, Menu
parser.parse();
domStyle.set(registry.byId("mainWindow").domNode, "visibility", "visible");
map = new Map("map", {
basemap: "streets",
center: [3.955, 59.338],
zoom: 3
map.on("load", createToolbar);
var measurement = new Measurement({
map: map
}, dom.byId("measurementDiv"));
measurement.startup();
function createToolbar() {
addGraphics();
editToolbar = new Edit(map);
//Activate the toolbar when you click on a graphic
map.graphics.on("click", function(evt) {
event.stop(evt);
activateToolbar(evt.graphic);
//deactivate the toolbar when you click outside a graphic
map.on("click", function(evt){
editToolbar.deactivate();
measurement.on("measure-end", function (evt) {
this.setTool(evt.area, false);
function addGraphics() {
//add pre-defined geometries to map
var polygonSymbol = new SimpleFillSymbol();
var polylineSymbol = new SimpleLineSymbol();
var text = new TextSymbol("Editable Text");
text.font.setSize("20pt");
var polygon = new Polygon({
"rings": [
[-4226661, 8496372],
[-3835304, 8731187],
[-2269873, 9005137],
[-1213208, 8613780],
[-1017529, 8065879],
[-1213208, 7478843],
[-2230738, 6891806],
[-2935181, 6735263],
[-3522218, 6891806],
[-3952711, 7165757],
[-4265797, 7283164],
[-4304933, 7635386],
[-4304933, 7674521],
[-4226661, 8496372]
"spatialReference": {
"wkid": 102100
var arrow = new Polygon({
"rings": [
[9862211, 6617856],
[8922952, 5522055],
[8922952, 5991684],
[6105178, 5991684],
[6105178, 7087485],
[8922952, 7087485],
[8922952, 7557114],
[9862211, 6617856]
"wkid": 102100
map.graphics.add(new Graphic(polygon, polygonSymbol));
map.graphics.add(new Graphic(arrow, polygonSymbol));
function activateToolbar(graphic) {
var tool = 0;
if (registry.byId("tool_move").checked) {
tool = tool | Edit.MOVE;
if (registry.byId("tool_vertices").checked) {
tool = tool | Edit.EDIT_VERTICES;
if (registry.byId("tool_scale").checked) {
tool = tool | Edit.SCALE;
if (registry.byId("tool_rotate").checked) {
tool = tool | Edit.ROTATE;
// enable text editing if a graphic uses a text symbol
if ( graphic.symbol.declaredClass === "esri.symbol.TextSymbol" ) {
tool = tool | Edit.EDIT_TEXT;
//specify toolbar options
var options = {
allowAddVertices: registry.byId("vtx_ca").checked,
allowDeleteVertices: registry.byId("vtx_cd").checked,
uniformScaling: registry.byId("uniform_scaling").checked
editToolbar.activate(tool, graphic, options);
</script>
</head>
<body class="nihilo">
<div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:'false'">
<div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:150px;text-align:left;font-weight:bold;font-size:14px;color:#400D12;">
<span>Specify options then click a graphic to edit the shape. Click outside the graphic to deactivate the toolbar.</span><br />
<div id="tool_move" data-dojo-type="dijit/form/ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Move</div>
<div id="tool_vertices" data-dojo-type="dijit/form/ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Edit Vertices</div>
<div id="tool_scale" data-dojo-type="dijit/form/ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Scale</div>
<div id="tool_rotate" data-dojo-type="dijit/form/ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Rotate</div>
<button data-dojo-type="dijit/form/DropDownButton" id="options" data-dojo-props="value:'options'">
<span>Options</span>
<div data-dojo-type="dijit/Menu" id="optionsMenu">
<div id="vtx_ca" data-dojo-type="dijit/CheckedMenuItem" data-dojo-props="checked:'true'">Allow Add Vertices</div>
<div id="vtx_cd" data-dojo-type="dijit/CheckedMenuItem" data-dojo-props="checked:'true'">Allow Delete Vertices</div>
<div id="uniform_scaling" data-dojo-type="dijit/CheckedMenuItem" data-dojo-props="checked:'true'">Uniform Scaling when Resizing</div>
</div>
</button>
<div id="measureToolsContainer" data-dojo-type="dijit/layout/ContentPane" title="Measure">Measure Tools
<br>
<div id="measurementDiv"></div>
</div>
</div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
</div>
</div>
</body>
</html>
