hi all, i am trying to use my 9.3.1 service in javascript api with token based authentication. I am getting blank map. i use proxy mentioned in this post
any idea what can be wrong? below is my header [ATTACH=CONFIG]15598[/ATTACH]
It gives same error when i login to the rest services from browser I my user is member of agsadmin group. I am able to login to Rest Admin (http://<servername>/ArcGIS/rest/admin/) using the same login. but gives unauthorised access as attached screenshot when i try to login to services directory (http://<servername>/ArcGIS/rest/services)
