Error: Unable to access DBMS server [[Microsoft] [ODBC Driver 13 for SQL Server] Communication link failure] [egdbdrone.USUARIOSGIS.Requerimientos]
588
09-10-2018 05:39 AM
JorgeBertin_Corvalan
Good morning, we have a web application developed in javascript and the ArcGIS API for JavaScript, is giving us the following error logs in arcgis server
"Error: Unable to access DBMS server [[Microsoft] [ODBC Driver 13 for SQL Server] Communication link failure] [egdbdrone.USUARIOSGIS.Requerimientos]".
In addition, in our programming he has delivered the following log:
System.Exception: ArcGIS REST API {"error": {"code": 500, "message": "Unable to complete operation.", "Details": []}} in App.Code.ArcGis.Layer.ReturnException ( String message) in c: \ Users \ caalvarezp \ Documents \ ESSAL \ Development \ Source codes \ Web - GeoMaps Technical Requirements \ 2.3.0 \ App \ App \ Code \ ArcGis \ Layer.cs: line 506 in App.Code.ArcGis .Layer.Add (Object attributes) in c: \ Users \ caalvarezp \ Documents \ ESSAL \ Development \ Source codes \ Web - GeoMaps Technical Requirements \ 2.3.0 \ App \ Code \ ArcGis \ Layer.cs: line 60 in App.Controllers.Views.RecordsController.Edit (FormCollection form) in c: \ Users \ caalvarezp \ Documents \ ESSAL \ Development \ Source codes \ Web - GeoMaps Technical Requirements \ 2.3.0 \ App \ App \ Controllers \ Views \ RequirementsController. cs: line 641
This happens intermittently happens from time to time, the issue is, we do not know what it is and it does not let us record from Collector to our database.
We need help.
Thank you very much.
