The following code in arcpy is used to convert a dwg file into shapefile and it works perfectly when you run it within arcmap:
import sys, zipfile, arcpy, os, traceback
from arcpy import env
# Set environment settings
env.workspace = "C:/GISApplication/GIS/Layer_Updated_Drawings"
# Set local variables
fileName = arcpy.GetParameterAsText(0)
featureType = arcpy.GetParameterAsText(1)
file = os.path.join(fileName, featureType)
inFeatures = [file]
outLocation = "C:/GISApplication/GIS/Layer_Updated_Drawings/Converted"
# Execute FeatureClassToGeodatabase
arcpy.FeatureClassToShapefile_conversion(inFeatures, outLocation)
However when I try to run this script using the following javascript code:
url = ARCGIS_SERVER + 'Toolbox/DwgToZippedShapefile/GPServer/LayerUpdate';
convParams = {
FileName: "MIPBoundary.dwg", //Hardcoded for testing
FeatureType: "Polyline" //Hardcoded for testing
convExportToolName = "SHPFileResults";
convJobFolder = "DwgToZippedShapefile_GPServer";
var gpConversionProcess = new Geoprocessor(url);
gpConversionProcess.submitJob(convParams, gpConversionComplete, gpConversionStatus, gpConversionFailed);
it keeps failing and I keep getting the following error on arcgis server manager:
Error executing tool. LayerUpdate Job ID: j7af4b50ca616491eb13dce08dfe17b7f : Traceback (most recent call last): File "(PATH)\Toolbox\DwgToZippedShapefile.GPServer\extracted\v101\my_toolboxes\UpdateLayer.py", line 25, in arcpy.FeatureClassToShapefile_conversion(inFeatures, outLocation) File "(PATH)arcgis\server\arcpy\arcpy\conversion.py", line 2775, in FeatureClassToShapefile raise e ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Input Features: Dataset Boundary.dwg\Polyline does not exist or is not supported Failed to execute (FeatureClassToShapefile). Failed to execute (LayerUpdate). Failed to execute (LayerUpdate).
However I don't know why it isn't working as I am passing all the parameters and when running the tool in arcmap with the exact same parameters it works fine.
