Feature Layer fails to draw with normalized symbology
651
04-23-2013 06:17 PM
StephenLead
Regular Contributor III
I vaguely remember posting something about this on this forum a few years ago but I can't remember the outcome.
It appears that a featureLayer will fail to draw if its symbology is normalized in ArcMap. To reproduce, add a polygon layer to ArcMap and set up a Graduated Color symbology, and Normalize with the Percent Of Total option chosen. Publish this to ArcGIS Server.
This service will draw correctly as a dynamic layer, but not as a feature layer.
A workaround is to manually calculate a new "normalize" field in ArcMap and symbolise based on that. Is there any chance this could be fixed so that the feature layer correctly uses the normalized symbology?
Steve
RachelFrischeisen
New Contributor III
Found your old post when searching on this topic here!
I also would be interested in knowing if this issue is being addressed. Creating a separate field for normalization works but is not practical when dealing with lots of data layers, such as one would with Census data.
