Feature table query date issues
1166
02-24-2017 08:16 AM
AndréRibeiro
I'm having some issues querying the feature table in ArcGis JavaScript API. I already had developed query by string and coded values with success but the date fields not, unfortenely.
Can someone help me with this issue?
This is my code to query by a string field "nud":
HTML
<input id="stringTextBox" type="text" data-dojo-type="dijit/form/TextBox" data-dojo-props="trim:true, intermediateChanges:true" class="dijit-form-TextBox filterTb"
<button type="button" id="confirm">Filtrar</button>
JAVASCRIPT
var confirmar = dom.byId("confirm");
on(confirmar, "click", function(value){
              var userVal = dijit.byId("stringTextBox").get('value');
              var oidFld = myFeatureLayer.objectIdField;
              var query = new Query();
              lastWhere = query.where = "nud LIKE '%" +  userVal + "%'";
            myFeatureLayer.queryIds(query, lang.hitch(this, function(objectIds) {
               myFeatureTable.selectedRowIds = objectIds;
               myFeatureTable._showSelectedRecords();
TomSellsted
MVP Regular Contributor
Andre,
Looking at your query, it looks like you are trying to do a wildcard selection of a date field.  Please try using a more specific selection like:
query.where = "nud = '" +  userVal + "'";
Date fields can be a bit tricky to work with as they may contain date/time values so finding an exact match would mean also have to specify a time or time range.  Something like:
query.where = "nud between '" + userVal + " 00:00' and '" + userVal + " 23:59'";
Regards,
Tom
AndréRibeiro
Thank you for your time Tom!
I already did that query, but I'm having the same issue before. I have an error on console: "Unable to complete operation".
Maybe query date fields are different of query another type fields like text?
Here's my code:
HTML
<input id="data1" type="text" data-dojo-type="dijit/form/TextBox" data-dojo-props="trim:true, intermediateChanges:true" class="dijit-form-TextBox filterTb" style="width: 100px;"/>
<input id="data2" type="text" data-dojo-type="dijit/form/TextBox" data-dojo-props="trim:true, intermediateChanges:true" class="dijit-form-TextBox filterTb" style="width: 100px;"/>
<button type="button" id="confirm4">Filtrar</button>
Javascript
var confirmar4 = dom.byId("confirm4");
on(confirmar4, "click", function(value){
   var userVal4 = dijit.byId("data1").get('value');
   var userVal5 = dijit.byId("data2").get('value');
   query.where = "data_de_inicio between '" + userVal4 + " 00:00' and '" + userVal5 + " 23:59'";
Thank you,
André
AndréRibeiro
I already did it, thank you so much!
Now I'm struggling with one thing more. I query the feature table records, but I want to query the records on map too, on feature layer, how can I achieve that?
TomSellsted
André,
Are you wanting to highlight the selected features on the map?  You can easily highlight them by setting a selection symbol.  Here is the documentation that might help with that:
FeatureLayer | API Reference | ArcGIS API for JavaScript 3.19
Regards,
Tom
