Hi everyone,
Does anyone happen to know, when trying to set conditional visibility on FieldElements in the Editor and FeatureForm widgets, do the Arcade expressions not work if it's on a field that has a coded value domain?
I have an address hosted feature layer that I've brought into my API for JS app, and in both my Editor widget I'm trying to make three of the fields (each has a coded value domain) only visible if the user enters a value for a fourth field. I've verified that my arcade expressions are correct, they've been declared in an object that is named in the formTemplate's expressionInfo property. But they won't hide.
I was leaning towards the answer being yes because I tried the same thing by making my City and State fields (no domains) visible only after the user picks a value for the ZipCode field (has a domain), and it does hide the fields.
note: this is on v4.23
Any insight is appreciated. Thanks!
