Filtering a CSV Layer
1077
11-15-2016 08:57 AM
ChristopherSchreiber
Occasional Contributor II
Hello all,
I am adding a CSV layer to my JS map. Is it possible to filter the layer by attribute values using the JS API?
I have tried using the "setDefinitionExpression" method but it seems to only work with Esri  Map services or Feature Services. Am I missing something?
Thank you!
Chris
JohnGrayson
Check out the doc: CSVLayer | API Reference | ArcGIS API for JavaScript 3.18
  • Does not support queries that need to be performed on the server, e.g. queries with a where clause or non-extent based spatial queries.
JohnGrayson
Thanks!
