My suggestion template for a search digit produces typical simple output, example:
suggestionTemplate: "${BILLNAME} - ${PIN}"
I'd like add a return between two values, such as:
suggestionTemplate: "${BILLNAME} </br> ${PIN}"
Is there a way to embed a line break (or other goodness)?
I played around suggestion template sandbox, but could not figure a way
ArcGIS API for JavaScript Sandbox
thanks
Pat,
It can be done with some css and \n in the template:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <title>Search with Suggestion Template</title> <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } #search { display: block; position: absolute; z-index: 2; top: 20px; left: 74px; } .searchMenu.suggestionsMenu>div>ul>li { display: block; white-space:pre; } </style> <script src="https://js.arcgis.com/3.15/"></script> <script> require([ "esri/map", "esri/dijit/Search", "esri/layers/FeatureLayer", "esri/InfoTemplate", "dojo/domReady!" ], function (Map, Search, FeatureLayer,InfoTemplate) { var map = new Map("map", { basemap: "gray", center: [-82.93, 42.5], // lon, lat zoom: 10 }); var search = new Search({ sources: [{ featureLayer: new FeatureLayer("http://services.arcgis.com/b6gLrKHqgkQb393u/arcgis/rest/services/TaxParcelQuery/FeatureServer/0", { outFields: ["*"], infoTemplate: new InfoTemplate("Parcels", "Owner name: ${OWNERNME1}</br>Parcel ID: ${PARCELID}</br>Site address: ${SITEADDRESS}") }), outFields: ["OWNERNME1","PARCELID","SITEADDRESS"], displayField: "OWNERNME1", suggestionTemplate: "${PARCELID}: \n${SITEADDRESS}", name: "Parcels", placeholder: "example: Shawn Smith", enableSuggestions: true }], map: map }, "search"); search.startup(); }); </script> </head> <body> <div id="search"></div> <div id="map"></div> </body> </html>
Pat,
Works perfectly! thanks
