generateToken not working
2301
02-25-2016 11:20 AM
KyleDunaway
I'm trying to generate a token to access
http://landscape1.arcgis.com/arcgis/rest/services/USA_Geology_Units/MapServer
var params = {
  username: username
  password: password
  //referer: 'http://l' + $(location).attr("host") + '/',
  referer: 'http://landscape1.arcgis.com/arcgis/rest',
  expiration: 1440,
  f: "json"
$.ajax({
    url: "https://www.arcgis.com/sharing/rest/generateToken?",
    type: "POST",
    dataType: "json",
    data: params,
    success: function (data) {
      the token in the data object is not working, the landscape1 just redirects to the login page.
Any ideas?
EvelynHernandez
Here my function for that. I hope this helps.
function validate() {
var username =  'YOUR USERNAME';
var password = 'YOUR PASS';
    var http = new XMLHttpRequest();
    var url = "YOUR TOKEN URL";
    var str1 = "username=";
    var str2 = "&password=";
    var str3 = "&f=json&client=requestip&expiration=1440";
    var params = str1.concat(username, str2, password, str3);
    //f="json", client="requestip", expiration="1440"
    http.open("POST", url, true);
    http.setRequestHeader("Content-type", "application/x-www-form-urlencoded");
    http.setRequestHeader("Content-length", params.length);
    http.setRequestHeader("Connection", "close");
    http.onreadystatechange = function () {
        if (http.readyState == 4 && http.status == 200) {
            var tokenResponse = http.responseText;
            token=JSON.parse(tokenResponse);
            if (tokenResponse.search("error") == -1) {
                esri.id.registerToken(
                {server:  'YOUR REST SERVICE',
                  userId:  'YOUR EXAMPLE USER',
                  token:  token.token,
                  expires: token.expires,
                  ssl:    false
                //DO SOMETHING
        } else {
                alert("Incorrect Login, try again.");
    http.send(params);
    return false;
