Hi guys,
I hope this message finds you well. I am currently facing an issue with the GeoJSONLayer renderer in the ArcGIS API for JavaScript version 4.29, and I was hoping you could provide some insights or assistance.
I came across an example on CodePen that demonstrated successful clustering with a unique value renderer in past versions (4.26 and 4.28). However, after updating to version 4.29, the functionality is no longer working as expected. It seems that each render is using the default symbol for all statuses, leading to broken rendering.
To illustrate the problem, the original creator of this CodePen example can be found here: Link to CodePen 4.28
and Link to CodePen 4.29
I would appreciate it if you could take a look and let me know if you have any suggestions or if there are known changes or issues in version 4.29 that might be causing this behavior. Your expertise on this matter would be highly valuable.
Thank you in advance for your time and assistance.
