Hi Everyone,
I am facing a weird issue. I am accessing a geoprocessing service in my web application, which is built on a custom python script. The script has some user input parameters, which when running from web application is sending them as parameters.
I can verify parameters as correct by using Developer tools, but the geoprocessing service accepts all parameters except one and returns result on default value of the python script.
However, when I open the geoprocessing rest service exceute task as a stand alone on browser, use same parameters as shown in Dev tools and run it; it creates proper result.
Also, I am using ArcGIS JS 3.39, can I use Get method instead of Post method for execute command of geoprocessing service and tie it is parameter variables.
If it's required I can share the code references.
Regards
