GP Link in Popup Panel Widget
894
04-11-2017 08:18 AM
LesiMai3
I'm trying to have a GP tool link (ArcGIS API for JavaScript Sandbox) appears in the Robert's Popup Panel Widget https://community.esri.com/docs/DOC-7355 . I'm using the 2.1.1 version of the widget. How can I overwrite the map popup used in the widget?
Thank you for your help!
Lesi
RobertScheitlin__GISP
Lesi,
  In the Widget.js make these changes (add lines 25-33 and 43-47):
      postCreate: function () {
        this.inherited(arguments);
        this.popupMenu = PopupMenu.getInstance();
        this.featureActionManager = FeatureActionManager.getInstance();
        domUtils.hide(this.actionsPaneDiv);
        this.own(on(this.domNode, 'mousedown', lang.hitch(this, function (event) {
          event.stopPropagation();
          if (event.altKey) {
            var msgStr = this.nls.widgetverstr + ': ' + this.manifest.version;
            msgStr += '\n' + this.nls.wabversionmsg + ': ' + this.manifest.wabVersion;
            msgStr += '\n' + this.manifest.description;
            new Message({
              titleLabel: this.nls.widgetversion,
              message: msgStr
        this.popup = this.map.infoWindow;
        this.zt = domConstruct.toDom('<a title="Zoom" to="" class="action zoomTo" href="javascript:void(0);"><span>' +
                                    esriBundle.widgets.popup.NLS_zoomTo + '</span></a>');
        domConstruct.place(this.zt, this.actionsListDiv);
        var link = domConstruct.create("a",{
          "class": "action",
          "id": "statsLink",
          "innerHTML": "Population", //text that appears in the popup for the link
          "href": "javascript: void(0);"
        }, this.actionsListDiv);
        //when the link is clicked register a function that will run
        on(link, "click", lang.hitch(this, this.calculatePopulation));
        this.clearSel = domConstruct.toDom('<a title="' + this.nls.clearseltip +'" to="" class="action clearSel" href="javascript:void(0);"><span>' + this.nls.clearsel + '</span></a>');
        domConstruct.place(this.clearSel, this.actionsListDiv);
        topic.subscribe("widgetsActionsRegistered", lang.hitch(this, this._onWidgetsActionsRegistered));
        this._createPopupMenuButton();
        this.setEvtHandlers();
        this.onWindowResize();
      calculatePopulation: function(){
        var feature = this.popup.getSelectedFeature();
        console.info(feature);
        console.info("calc pop clicked")
Lesi,
          if (event.altKey) {
            new Message({
              message: msgStr
          "class": "action",
          "id": "statsLink",
LesiMai3
Thank you Robert!
