Here is my current scenario.
I need to gain access to a SQL Server called say, SERVER1. Below is the custom SQL Query that I Need to utilize in order to get the most recent GPS record. I can't seem to figure out how to utilize this in my JavaScript Application to get this data. Of course once I get the data I need to dig into it to get the lat/lon, convert it, then map it. One step at a time. Perhaps using $.ajax to do a GET but not quite sure how to go about this.
SQL Query:
SELECT S.MSGTEXT FROM [dbo].[Syslogd] S INNER JOIN (SELECT T.[MsgDate] AS 'MSGDATE' ,MAX(L.[MsgTime]) AS 'MSGTIME' FROM [KiwiSysLog].[dbo].[Syslogd] L INNER JOIN (SELECT MAX(MSGDATE) AS 'MSGDATE' FROM [dbo].[Syslogd]) T ON L.MsgDate = T.MSGDATE GROUP BY T.MSGDATE) DT ON S.MsgDate = DT.MSGDATE AND S.MsgTime = DT.MSGTIME
Results in Microsoft SQL Server Management Studio Express:
$GPGGA,222020.0,3609.839478,N,11509.243300,W,1,08,0.8,618.9,M,-18.0,M,,,9999*4F $GPRMC,222020.0,A,3609.839478,N,11509.243300,W,1.1,302.7,270416,0.0,E,A,9999*34
I appreciate the help.
John
I way overthought what I was doing. I registered the database on Server then utilized the QueryTask as stated. I then created the query for the values and then pushed those into an array and converted them into lat/lon as needed then created a graphic for them and added them to the map. Problem solved. Thank you all for the input.
